monkeysolder
I don't have enough practical experience with video compression to answer this question so I'll ask you guys. I'm trying to spec out a video capture system running on a Pentium 738 (Pentium M 1.4GHz, Low Voltage) embedded computer system. It has "framegrabber" cards integrated that use the Conexant BT878 Fusion video capture chip. Each PC104+ card using this chip is able to accept 3 video inputs (6 total inputs) and present the data to memory/processor, but I would like to write the video to a hard drive. I believe this will require some sort of compression (correct me if I am wrong). I am unsure if this chip has a built in hardware encoder for MPEG, but it does not appear so. My question is this: If I want to write all 6 channels of video to a hard drive, do I need encoding and will I be able to do this seemingly large amount of software compression on this type of computer system?
The spec sheet for the PC104+ board with the video capture chip is at:
Thanks,
Thanks,
