Vibration Analysis
  • Thread starter Thread starter mecbat
  • Start date Start date
M
mecbat
Guest
I have a plastic housing mounted on a steel bracket. I have to do a vibration test on a shaker table. the information of vibration spec is as follows:
Sweep Type: Log
Time Per Sweep: 20 min
Sweep per Axis: 18
Total Sweep: 54
Total Test Duration: 18h
Electrical operation mode: 3.2c
For Axis: X,Y and Z ---Acceleration : 10 mm p-p Displacement limited, Frequency : 5 -15 Hz / Acceleration :4.5g for Frequency 15 - 25 Hz / Acceleration : 2g for 25 - 100 Hz / 0.5g for 100 - 200 Hz
How will you approach this Analysis in Pro/Mechanica? Please share your thaught. Thank you.
