I have a VFD that I have to derate because of its sissy temp rating. It has to be put in an enclosure and if the air temp in the enclosure exceeds a mere 104F/40C I have to derate the drive to 80%. So it's a 25HP motor stating 29A I'm using a 30HP (47A)drive.
How do I have to rate the wiring and protection. Do I have to scale that all up when I'm only actually using the drive's larger semiconductors and heat sinking and none of the drive's larger HP capability?
Any chance I can rate it all against the motor's name plate FLA?
I can image the answer... Code answer always = sux.
Keith Cress
kcress -
Keith Cress
kcress -
