very low temperature compressor
nrgy
I have searched the web to no avail to locate a small
(1 to 2 hp) compressor for compressing nitrogen at  -150 C(-240F) with a compression ratio of about 4.
I would appreciate any information on compressor design limitations at very low temperatures.
Thanks for your help
nrgy,
"Compression ratio of about 4" isn't enough information to help. If you want to go from 0.2 bar(a)to 0.8 bar(a) you'll be looking at a different machine then if you want to go from 1 bar(a) to 4 bar(a) or 100 bar(a) to 400 bar(a), etc.
For any compression application you need to know: (1) what is your target suction and discharte pressure and temperature (the heat of compression for 4 ratios would raise the temperature to -92C, is that too warm?); (2) how tolerent are your downstream processes to oil contamination?; and (3) what is your desired compression volume (different required capacities point you toward different technologies)? Many manufacturers make cryo compressors in various technologies.
At -150C you are only 45C away from the boiling point, it might be less expensive for a small volume to "compress it" by cooling it to a liquid and pumping it.
David Simpson, PE
MuleShoe Engineering
The harder I work, the luckier I seem
Thanks muleshoe.
The system is for a liqN2 powered engine with vaporization of the liqN2 by a secondary gas(N2 or air).
The compressor is to pressurize the cooled secondary gas from 1 atm. to 4 atm., thus economizing the liqN2 and using minimal compression work.
Hope this makes sense
Not really, please see the three questions I asked above.
David
David,
1. compression is from 1 atm. to 4 atm, Outlet of -92 C is acceptable.
2. oil should be tolerable downstream but probably not good to discharge to atmosphere.
3. not sure what you mean by compression volume. Volume flow is about 6 cfm at outlet conditions.
Thanks for your help,
Steve Kaufman
