Very High temp refrigerant help
seasar
Can someone point me to a resource that helps identify refrigerants given specific parameters?
The app in question is recovering heat from a 210F, 2 psig source to a 350F, 150 psig sink.
Water could be one possibility. The system would need to be a closed loop.
Hi Seasar , can you state fluids involved , and flow or heat to recover.
The source is low pressure saturated steam (2 psi) from a vapor condenser. The sink is a steam accumulator at 150 psi.
Possibly an absorber would work. More detailed info would help.
