Referring to control valves, I sggest that pneumatic positioners should be mounted upright for the correct influence of gravity on the mechanical linkages?
Incidentally, several years ago I discovered several large conventional safety relief valves mounted sideways rather than upright during an offshore platform audit. These must be mounted upright as the plug and stem weight under gravity works in conjunction with the spring load,
