Vertically downward output shaft
L17Aurora
GB
In general - Is there an oilseal that could cope with a vertically downward output shaft, or do all "designed" boxes have weirs and grease on the lower bearing on this type of unit e.g. mixers, agitators etc?
Cheers
Mick
From the Rexnord catalog, Falk RAM Mixer drives
No-leak drywell design physically separates the oil sump from the output shaft to eliminate gear oil contamination of your product.
Russell Giuliano
Given proper design and installation, all contact-type oil seals will work fine for a long time in a shaft-down installation ... until they fail.
Weirs, drywells, etc, are the logical evolutionary response to a perceived or real need to avoid contamination of whatever is being mixed even when the oil seals leak.
Need a super-short box?
Can afford regular preventive maintenance?
Are really tall when you're sitting on your wallet?
Given that last, nearly anything is possible.
Mike Halloran
Pembroke Pines, FL, USA
