Hi guys,
I have a little problem. I'm trying to determine the inlet flow velocity of fluid to my pump. It's a 4 stage vertical turbine pump and its situated to one end of a well. Water flows into the well via a 24" diameter pipeline at an entrance velocity of approximately 8 ft/sec. Now the distance between the point of entry of the water and the pump's suction strainer is 10 feet. I wanted to know how do you determine the entrance velocity of the water be by the time it reaches the pump? Or is it almost negligible because of the distance involved? Its potable water with a specific gravity of 1.0 and the well is about 16 feet deep. Thanks for any help you may be able to offer.
