Vertical Text Alignment in Note.
  • Thread starter Thread starter joenjoe
  • Start date Start date
J
joenjoe
Guest
I can alter the horizontal alignment (Left, Center, Right, Default) under Note/Dimension on the Text Style tab. However, the vertical option is greyed out, so I cannot alter this (Top, Center, Bottom, etc). Please advise if anyone has any ideas how toget around this.
Thanks.
Vertical option for text positioning is available for selection only for the "On Item" notes and in table cells.
Thank you, contour. It is frustrating that vertical text can not be selected for standard leader notes. But at least now we know.
You mean "Alignment" or "Orientation"? For orientation specify "Angle" right below "Vertical" in Text Style tab.
Edited by: contour
To Move Leader Attachment in a Multi Line Note:
In the Text tab, type "@o" (the letter o) at the beginning of the line of text you want the leader to attach to. Do not leave a space between the symbol and the text.
Edited by: contour
Thanks for the tip!
Tim
