vertical spindle, reciprocating table surface grinder
whirledpeas
5
Does anyone still make such an animal? I've spent an hour with Google and have only found very small machines.
Blanchards are rotary table. I am looking for a grinder with a vertical spindle like a blanchard, but with a reciprocating table like 90% of all surface grinders. Mattison used to make them, but I haven't been able to locate any new Mattisons. I assume they have gone out of business like so many other high quality machine tool builders.
I could swear I've seen big Blanchard brand grinders with segmented rotary heads and reciprocating tables. ... but I haven't seen a new one in decades.
Mike Halloran
Pembroke Pines, FL, USA
That is a possibility. I will check into it. I know Thompson used to manufacture them as well, but I can't find anything even close to new.
Thanks,
Bob
Lumsden also used to manufacture them but I don’t think they still do. There is a company in Norfolk UK that sells used ones and reconditions them and has all part drawings etc.
I am sure I can find a link if that is any help.
You maybe able to use this type Swisher Grinder for your
application.
Mark VI
We had a shop built hybrid made with a Swisher very similar to the one shown in the link below. If I recall the table was from a G&l surface grinder. This hybrid lasted for years seeing 20 + hours use per week.
per week grinding segmented blades for pelletizers.
Mattison Surface Grinder
Big old good one in the link below.
Mattison as well as others also made bar grinders. These have reciprocating tables. Mattison also makes a Blanchard look a like.
The original grinders of this type were call Hanchetts and then Madison Hanchetts.
I don't know if they are still in business but Snow in the UK used to make a good one -- on a practical basis yo might want to buy a used one and have it rebuilt to your specs.
Thanks to all for your responses. You all pretty much confirm what I suspected. If a Mattison type grinder is what I want, I will have to purchase a rebuilt, or a used one and have it rebuilt.
