Latexman
Chemical
- Sep 24, 2003
- 6,945
I'm out of my area and I need some guidance please.
I have an agitator that bolts to the center nozzle on the top head of a tank. The 316 SS, 114" long, 2.5" diameter shaft is solid and hangs vertically down into the tank. It has a 5 hp motor. The impeller turns at 100 RPM.
The agitator disperses a powder into water until it dissolves. The powder is added from 50 # bags by hand, one at a time. The powder will clump, but not in 50 # chunks.
I'm trying to get a conservative value of the maximum deflection at the bottom of the shaft so I know how much room I have to put in a steam sparger. The only nozzle I have available is at the same level as the bottom impeller.
What value of hydraulic force service factor would be recommended to account for dynamic operation in this service?
What is the modulus of elasticity (E) of 316 SS?
Is the second area of momentum (I) for a vertical, solid shaft with a horizontal force through it's center
I = pi.radius4/4?
Is deflection = Dynamic Force.Length3/(3.E.I)
Thanks!
Good luck,
Latexman
I = pi.radius4/4?
Thanks!
Good luck,
Latexman
