PSUengineer1
The attached photo shows a vertical crack in soldier course brick veneer mortar joint, where the soldier coursing meets the running bond brick veneer. Stair-step cracks are in the brick veneer below this area, which are probably from foundation settlement.
What is the cause of the vertical crack in the attached photo? Could it also be from settlement? thermal expansion of materials? No steel lintel observed above window. Not an expansion joint issue (this is a small ranch house). I am looking for a general description of the cause of the crack. thanks.
