Simple question. Is it ever appropriate to take a 10' diameter vertical storage tank (34' tall)and weld I-beam stilts to the shell effectively raising the bottom of the tank 12-18" in the air. I have never seen this done. I believe the installer did it to prevent corrosion from standing water within the secondary containment area. The stilts are seam welded to the sheel and extend up the shell approximately 24". The stilts are also welded to anchor plates embedded in the floor of the containment area. I feel I need to at least check these tanks for stability / overturning issues, and possibly localized stress issues in the shell. Anyone run into this before? I have been asked to assess the suitability of the tanks, which are currently in service and used ot hold recycled fuel oil. Thanks.
Chris
Chris
