Verrrrrrrrr.....y slow ROTATION/PAN of second open model
jack3108
CA
SW2005 - Windows XP - from Local drive;
- opened detail
- opened assy
- saved both under 2005
- exit SW
- started SW 2005 again
And now the problem:
- opened detail
- opened assy (in this order)
Assy slow like hell on ROTATION/PAN
- Closed both
- Exit SW
- Reopen SW
- open assy
- open detail (in this order)
Now detail slow like hell - that is Always the second solid model opened.
Haven't tried any more to open yet.
Anybody has seen that ???
After that used CONVERSION WIZARD and converted the models from SW 2004 to 2005 . Problem remains.
Thanks for answers - I am desperate.
What are your computer specs?
How much "normal" RAM?
How much graphics card RAM?
How much Virtual Memory?
[cheers] from (the City of) Barrie, Ontario.
[bugeyed] I tried sniffing Coke once, but the ice cubes got stuck in my nose [shocked]
Thanks - will try to dig out the info later.
What pisses me of is that there was NO such problem with the solid models under 2004 as recently as yesterday.
Did you use the download version of SW2005 or the CD version?
Used CD version (3 disks).
Now, another experiment - forget about previous assy - just tested with two PARTS,
- sprocket, file size 383 kb
- roller, file size 147 kb.
The second part (Roller) slow like hell.
Can you answer previous questions?
Did you do a "fresh" clean install or simply install over SW2004?
O.K. guys, appreciate - so far found this on video card:
NVIDIA GeForce2 GTS
Chip type GeForce GTS/GeForce2 Pro
DAC Type Integrated RAM DAC
Mem size 32 Mb
Adapter String GeForce2 GTS/GeForce2 Pro
BIOS Information: version 3.15.00.13.01
As Scott stated it looks like it's the video card & driver.
check to find the latest driver for your card, or better still upgrade your card to a certified one. I suggest the nVidia quadro fx500 for a starter.
Your video card is the problem. Even though it worked for SW04 doesn't mean that it will for SW05. SW05 is more demanding and 32MB card will not handle it. I'm really surprised SW04 did as well you say it did. But none the less your problem is your card.
However you might find something here that might help - thread559-87811 - if you can't get this to work then you should Highly considered (Honestly you should any way) replacing that card with one SW supports - Like a Quadro 500 FX - - Also see CBL link too.
Scott Baugh, CSWP [pc2]
faq731-376
- "fresh" clean install - actually the disk was "cleaned" and Windows XP installed first, then SW 2005 - previously I had Windows NT4.0 SP 6.0 and SW 2004 SP 4.2
Now, the computer data:
Model: Precision 330
Manufacturer: Dell Computer Corporation
Type: Desktop
Role: Member Workstation
Asset Tag:
Service Tag: 5FRZR01
Processor: Pentium 4 1700MHz (L1 cache: 8.00 Kb, L2 cache: 256.0 Kb) Ext.clock: 100 MHz
Proc.type: Pentium 4
Quantity: 1
Proc.freq: 1700 MHz
L1 cache: 8.00 Kb
L2 cache: 256.0 Kb
Ext.clock: 100 MHz
Proc.socket: Microprocessor
Family: 15
Proc.model: 0
Stepping: 10
Brand ID: Intel(R) Pentium(R) 4 CPU 1700MHz
Serial number:
Features: SIMD instructions
FXSAVE/FXRSTOR instruction
MMX extensions
36bit Page Size Extension
Page Attribute Table
CMOVcc (+FCMOVcc/F(U)COMI(P) opcodes
Machine Check Architecture
Page Global Extension
Memory Type Range Registers
SYSENTER/SYSEXIT extension
Processor contains an enabled APIC
CMPXCHG8B instruction
Machine Check Exception
Physical Address Extension
Model Specific Registers
Time Stamp Counter
Page Size Extension
Debugging Extension
Virtual Mode Extension
Built-In FPU
Bios: A09 (11-Oct-2001)
Motherboard: Precision 330 (Dell Computer Corporation) (Microprocessor)
Memory: 512 Mb (523 276 Kb) RIMM_1: 256 Mb(RDRAM,RAMBUS,2.5 ns) RIMM_2: 256 Mb(RDRAM,RAMBUS,2.5 ns)
Hard disks: 19.1 Gb (11.9 Gb free = 62.4%) (4.45 Gb free on C: drive)
primary disk: IC35L020AVER07-0 size: 19.1 Gb sernum: SVPTVLY6109
C:(Ntfs) 10.1 Gb (4.45 Gb free = 44.0%)
F:(Ntfs) 8.97 Gb (7.45 Gb free = 83.1%)
Remov.disks: A:
CD-ROM: YAMAHA CRW8424S SCSI CdRom Device (E:)
SAMSUNG CD-ROM SC-148C (D:)
Video card: NVIDIA GeForce2 GTS/GeForce2 Pro (32.0 Mb): 1024 x 768 - True Color (32 bit)
O.K. folks, when I close the first item (the fast one) then the second item that was SLO now becomes FAST on ROTATION/PAN
Need to upgrade your RAM, video card, bigger HD and maybe faster processor... I suggest 3.4 GHz minimum.
not less then 1 Gig of RAM and change that video card - that is your bottle neck! Set your Virtual memory to 3 or 4 times your amount of RAM and put it on a separate HDD - If you read the link I provided above, you would have read that placing your Virtual memory on a separate HDD will give you a perfromance increase of 15-30%.
But to get back to your question directly - the problem is your video card. Because as you rotate your models on the screen your Video card has to refresh itself each time it moves. The reason the one is fast and the other is slow, is because of the limitation of that card with multiple windows open at one time. - If you had went to CBL's website link ( you would have read about a limitation with mulitple windows open.
With the information you just provided above. You proved the case of the video card being the problem. The best solution is for you to change cards. Your second best choice would be or try the thread link I gave you above.
faq731-376
I would check one more thing beyond what Scott has posted and that would be to ckeck and see how much memory that the computer reports when it starts up. You may have lost one chip on the first memory strip on the computer.
jack3108
I'm with SBaugh. Pan and Rotation speed dependent on the number of opened windows it's a typical issue of low memory video card or opengl bug.
Maybe you can improve your system behaviour with one or more of the following:
- install better video card drivers (not always the latest is the best to run SW)
- adjust the Opengl settings of the video card (try to find some information on the net) specialy those regarding buffers and swaping
- if none of the above works, change SW option to software Opengl
Good Luck
