Venturi choke
triviaux_1
Petroleum
AE
I m using multiphase flow meters to measure well production and in several cases I could not reach the well head pressure needed (even at fully open production choke) due to the choking cause by venturi of the multiphase flow meter
In order to select properly my venturi size and well head choke size and I m looking for the equivalent choke size of the venturi
Sounds like a badly designed meter. Did you give the vendor all the correct parameters?
Different meters are better for different types of GOR.
Did you just use an existing meter or get them bespoke?
The meter manufacturer should be able to tell you the size of the orifice opening in the meter. This manufacturer list four sizes for their meters, which I assume are the orifice openings in the neck. Your production choke may be using reduced orifice trim that is no longer needed now that your well has been in production for a while. Your production choke may also not be opening fully. A simple trim change or servicing may solve your problems. If the meter is indeed the cause of the problem and not an undersized production choke as you speculate above, you may need to assess the cost of a new flow meter.
Gents,
Thank you for your feedback
Actually the well is flowing within the operating envelope of the multiphase meter no issue on that side and the pressure drop is not that high. My concern is the choking effect of the venturi indeed when we by pass the multiphase meter we reach a well head pressure of around 200 psi (choke fully open) however when we flow the well through the meter the minimum pressure at the well head is around 270 psi (choke fully open) we tried different size of multiphase meter with venturi of 50MM and 67MM same problem
So im wondering how can I estimate or calculate the choking effect of the venturi in order to avoid such problem in the future and select correct meter size
Thank you
