bethw
- Sep 29, 2003
- 39
I've come across a situation in a hospital where the newly installed boilers are not fitted with any type of valving on top for venting. The riser pipes are there but they are capped. Venting is now being done with a small petcock on top of each sight glass. They are now faced with the task of getting a code shop in there to remove the caps and install vent valves on each boiler. My question: Are vent valves required under the boiler and pressure vessel code?
