Still on my forklift mast to a fixed lift project ....
I want to install a velocity fuse ( hose break valve ) right after the cylinder.
The original unit did have one but after 30 years of acid spillage, it is in rough shape.
I think the original unit was a "calibrated" Parker valve part number 19012DWS-3-9.0 (3/8" female NPT one each end).
Same problem I had earlier ... local forklift distributors don't even what to talk with me and won't sell me a valve.
I did put a posting on a forklift forum. No one offered to sell me one but I was told it costs about $200
I did a quick search and found a velocity fuse made by Hydac.
Called the company who referred me to two "local" vendors. I called and sent e-mails to both.
Neither could not give me any information on them other than price and delivery if I picked out a unit and gave them a part number.
Turns out they are relatively cheap. Depending on the body $59 or $110 with a two week delivery.
I have one question. There is a minimum operating pressure of 145 PSI .... why? Is this the pressure drop across the unit ( the minimum pressure it takes to open the valve) or ????
Can someone double check me on the unit I chose ... like I said, the distributor would offer no help of advice.
The unit I chose is a RBXB-SAE1-1/16-12-X-120L/MIN or RBXX-SAE1-1/16-12-X-120L/MIN ( the NPT option is no longer available ).
I have a maximum flow of approximately 6 GPM ... I am guessing the 9.0 in the original valve may have been the shut off flow.
Here is a link to the catalog ... page 57:
Also, is there any other manufacture of a velocity fuse that I should look at?
Thanks once again ...... Mike
