I would appreciate help with what seems like it is probably a pretty easy fluid mechanics problem. I need to calculate the velocity change in a pipe due to an abrupt diameter change (see attached figure). I have the velocity in the larger pipe, and need to calculate the velocity in the smaller pipe.
I need the velocity in the smaller pipe in order to calculate the Reynolds #, which I need in order to calculate the friction factor, which I need in order to calculate the damping coefficient, which I need to plug into my FEM... this is the first time I have dipped my toe in the world of fluid mechanics since I graduated 10 years ago, so I am a little rusty. Any help would be much appreciated. I am doing some googling, and am coming up blank...
