I would like to know if the active window is a DMU Navigator or not. Can you help me ?
Below the code I use. When I launch it I have the error message at the line TypeOf activeWin Is NavigatorWindow:
Compilation Error:
Type defined by the user is undefined
Thanks for your help
Compilation Error:
Code:
Sub VerifierDMUNavigator()
Dim activeWin As Object
Set activeWin = CATIA.ActiveWindow
' Check if the active window is an instance of NavigatorWindow
If TypeOf activeWin Is NavigatorWindow Then
MsgBox "You are in DMU Navigator"
Else
MsgBox "You are not in DMU Navigator."
End If
End Sub
