VB6 Sorting records
derrick
Computer
Jun 13, 2001
40
I need to read a file containing about 250,000 records, sort them, and write the resulting list to another file.
List boxes are restricted to an index of 32,767. Although I can enter more items in a sorted listbox and refer to them in order by reading the first index, then deleting it so that the next list item is available, the sorting is far too slow.
Is an array of records using a sorting algorithm the best answer?
Any brillaint solutions anyone?
I've never done it, but I believe that ADO can read text files as a recordset. This then provides access to the ADO sorting and recordset handling capabilities. Mayble this would help.
Alternatively, unless this specifically needs to be done through VB, you could use MS Excel.
During research I have found the 'RADIX' sort, very fast and very stable.
Would recommend it to anyone sorting large files.
