remp
- Sep 15, 2003
- 224
Can somebody please tell me the best way for the BMS to calculate what the supply air temperature should be set at in a VAV system that has heating and cooling coils in the air handling unit. The cooling coil was designed for an off coil temp of 12 Deg C and the heating coil was designed for an off coil temp of 28 Deg C. This is for max cooling and max heating. How do I reset the temp sensor in the suppl;y duct so as to control the operation of the Heating and cooling valves.
Thanks!
Thanks!
