In a closed water circulation system with 2-way valves at the consumers and the constant head control, when the valves close, the system resistance and head increases, the system curve comes up and the control through an invertor lowers pump's rpm. Pump curve goes down and the head is kept at a set (constant) level - the horizontal line on the flow-head diagram. But what is going on when the varying head control is used - when the line on the diagram is kept inclined and there are two set points - the head and 1/2 head (Grundfos)?
