Variable voltage pulse output
Sa-Ro
279
This is regarding PWM, PFM Concept
Ref: attachment
I am having a arbitrary function generator ( TEKTRONIX AFG310000 series) where I can design my pulse wave form with constant voltage output and duty cycle.
I need a device like arbitrary function generator where I can design my pulse wave form with voltage amplitude (from 0 to 300V AC / DC) and duty cycle.
Voltage: 0 to 300 V AC and DC
Current: 10 Amps
Frequency: 100 KHh
 https://files.engineering.com/getfile.aspx?folder=71641044-43f9-459b-8c26-675db0e323c1&file=IMG_20200408_221040.jpg
So, what does this have to do with PLCs; it doesn't look like you need much in the way of logic.
There are AWGs that have programmable waveforms, including their amplitudes. A 3kW output is not in the realm of PLCs, nor off-the-shelf designs, particularly when coupled with 100 kHz operation.
It's likely you need to hire someone for a custom design.
TTFN (ta ta for now)
From your description it sounds like you are trying to control a motor. Yes?
Brad Waybright
It's all okay as long as it's okay.
It is for solenoid coil development and optimization.
