cardoso115
Computer
I'm trying to build a variable DC power supply, I'm using TL494 for PWM and a NPN transistor as the switch.
I'm using a Buck topology, and my problem is that my voltage is fine without any load applied to it, but when I connect a simple led with a resistor the voltage drops a lot.
I'm not using any feedback on the TL494.
Thanx in advance, Carlos Cardoso
