Hello People
I have searched through some of the preceeding threads relating to this topic but I've had trouble getting any of the tip to work. Basically I need a helix that satisfies the following criteria
2 turns
Start rad = 30
rad at end of turn 1 = 30
pitch between start point and end of turn 1 = 30
rad at end of turn 2 = 25
pitch between start point and end of turn 2 = 20
I then need to sweep a section along this helix, I also tried doing it in 2 using expressions from a sketch to control the pitch however the 2 were not tangential so it failed.
Any help would be greatly appreciated.
Best regards
Simon (NX4.0.4.2 MP4 - TCEng 9.1.3.6.c)
If it can't be fixed with a hammer, then it must be an electrical fault...
2 turns
Start rad = 30
Best regards
