I use NX6 to make a cylinder with a large amount of variable holes. After reading thread561-296588 i am able to create a series of 90 points on my cylinder. However the points does not show up in the "Part navigator". I have created some holes by manually selecting each point, but the problem is that the hole size vary, and its very much work specifying each hole diameter.
any tips?
any tips?
