Do you mean with a roller or flat tappet.
I guess a rev kit might bleed them down, even on the base circle until the tappets were wide opened, depending on oil supply rate and bleed of rate at the rev kit spring pressure.
I also guess that if the clearance is taken up on the base circle, there is no need for opening ramps, just closeing ramps.
I guess they would have some effect as the opening rate and total lift would bleed down a little at low speed, but the ramps would reduce the bleed down effect on the closeing side, not eliminate, but reduce the effect.
Now you got me thinking, a dangerous move at any time.
With a few experiments re oil supply rate, bleed down rate and rev kit spring pressures, I might only lose 3 or 4 cams before I got it to work. Then again, I don't get enough time to sleep as it is Regards
pat
