to 22082002, since you are speaking just of theoretical simulations, let me enlarge a bit what I have intended to say before. In principle, on a PT graph vapour pressures of individual hydrocarbons would be represented by a line stopping at the critical point (CP), as shown in the well-known Cox chart.
You are right, the CP for a pure species is the highest temperature and highest pressure at which vapour and liquid phases can coexist.
However, for a mixture it is in general neither.
The CPs of mixtures vary and are located on a curve (the locus) that changes with composition, under most conditions the CPs aren't located at the maximum values of P and T. This curve is the locus of the bubble points (to the left of the CP) and the dew points (to the right of the CP).
For a given composition the equilibrium curve around the CP bulges to the right, with the CP somewhere on the bulge, but -in general- neither at the highest temperature nor at the highest pressure. To the left of the CP, one single (vertical) temperature cuts the equilibrium lines at two points: the higher one representing the liquids' bubble point (i.e., VP); the lowest intersection being the vapour dew point. By being on a temperature between the bulge's maximum, and the CP, it is possible to cross the dew point line and to partly condense the vapour by reducing the pressure.
This is called retrograde condensation.
This phenomenon is of importance when operating some deep natural-gas wells where the prevailing conditions are to the right of the CP temperature of the mixture but still below the maximum saturated vapor dew point equilibrium temperature. When isothermally removing gas, the total pressure in the well drops and part of the nat-gas (butanes and heavier) liquefies, a fact that may lead to a reduction in the production of the well when the liquid is trapped in the sands. Repressurizing the well by lean gas, that has been removed from the condensing heavier species above-ground, is commonly used to return the underground reservoir to an elevated pressure and a more favourable equilibrium composition.
In summary, yes, vapour pressures (bubble points) can, in principle, be higher than the critical point pressures of a hydrocarbon mixture.
