In general, gas load factors (or K-values) used for sizing vane packs are in the range of 1.00-1.25 m/sec for atmospheric pressure conditions. Similarly to demister pads, pressure de-rating factor is applied to predict performance at elevated pressures.
I wouldn't recommend using vane packs in systems above 10-15bar since their performance deteriorates exponentially above these pressures - especially if high liquid removal efficiency is required (e.g upstream of mol sieve dehydrators or compressors). A usual way to go is to employ:
1. Vessel large enough (no one can beat the gravity)
2. Mistmat as primary coalescing element, 100-150mm thickness, stainless steel
3. Cyclonic devices as secondary coalescers
We've had quite bad experience with vane packs in our Mol Sieve unit (KO drum) which operates at 70barg pressure. This system simply doesn't work and I would never believe to separator internals vendors, regardless of what they say.
