ahmadbazzari
hi
am a fresh graduated mechanical engineer working at " wast water pumping station " put i became some nervous from some welding and pipeline design basic
so many questions on my head
like ....
1) can we weld two fittings together ?
2) can we weld fittings directly to a valve ?
3) can we weld two valves directly ?
4) what is the allowance distance between any two fittings , any valves , or fittings ( elbow reducer or tee ) between them-self or between them and other valves ?
5) what is the distance between two pump ( one duty and the other is stand by ) ?
6) when i have to make a header between two pump , what is the allowance distance between the upstream and down stream , and suction port and draining port ?
i know that a lot of questions but i hop to help me or at least give me some basic or books to start learning
thank you ^_^
like ....
thank you ^_^
