My Boss asked me to provide him with throttling valve in the following condition, I am still a rookie and wonder how to solve:
he would like a Cv of 40 based on his data:
Operation: Start-up, 3 years, Typical (3 years)
Fluid: Water
Water - Total dissolved solids: 5,100 ppm
Water - Chloride concentration 2,600 ppm
Water (pH): 9.3
Temperature: 22, 15, 19
SG: 1.0
Upstream Pressure (Bar): 7.7, 12.5, 10.0
Pressure Drop Bar: 6.7, 11.5, 9.0
Flow Rate (m3/hr): 47.6
Materials of Construction: advise (me)
No. of Reject Valves Required: 4 units.
I am asking where to start, how do I compute my boss' above data with my existing valve data below to see if we are within the operating range.
Existing Valve:
1,2, and 3" sizes
Working Pressure: 5000 psi Max.
Max Pressure Drop: 45000 psi Liquid
Temp.: -20F to 450F
Body config.: "Y", ANgle
End Connection: NPT, Socket-Weld, Flanged.
Trim: Linear Cage.
Flow Direction: Over & Under Plug.
Repeatability: 2%
Shut off: Bubble Tight @ Rate Pressure
Actuation: Manual Handwheel or Electric Actuation.
** If we can use the existing valve with the proposed condition, then what type of Trim to be used. I sincerely appreciate for whoever paying attention to this posting.
Fluid: Water
Water (pH): 9.3
SG: 1.0
Existing Valve:
1,2, and 3" sizes
Temp.: -20F to 450F
Trim: Linear Cage.
Repeatability: 2%
