I've seen various claims of valve spring power consumption of 20-35% of gross power for 2-valve pushrod engines. In our own application, inline 4-cylinder w/peak horsepower of 335@6400RPM, I can calculate approximately 100HP used to open the valves. This was based on the work done from the cam base circle to the nose of the lobe.
However, isn't this same work performed in the opposite direction as the spring helps to drive cam on the back side of the lobe? I realize there will be some frictional heat loss in the spring, and valvetrain inertia will loft the lifter briefly after max lift. I have a hard time believing that the net work done is not closer to zero.
What am I missing here?
