mgwilkinson
Hello All,
I am an engineering student, so forgive me if this seems basic or is otherwise indicative of my inexperience with valve design and selection.
I am curious as to how valves are rated if they are going to be used in a vacuum application. This is to say, if the valve is separating a vacuum chamber operating at a high vacuum from something else, like a vacuum pump, would the required ratings for the valve be any different than a valve operating where the items on either side are at atmospheric pressure? In this case, the valve is controlling the flow of air between the chamber and pump. Is a purpose-built valve required, or, provided a solid seal is achieved, would any correctly sized, correctly mated valve do the job?
Thus far, the standards I've come across for valves (ANSI 150, ANSI 300 and B16.34) don't specifically address this. Most of the spec sheets for valves I've looked at list a psig rating, but nothing indicating their ability or inability to operate in the vacuum pressure range.
Any help you all could offer would be greatly appreciated.
Kind Regards,
MG Wilkinson
Worcester Polytechnic Institute
Mechanical Engineering
Kind Regards,
MG Wilkinson
