I'm trying to retrofit some old manual Grove gate valves (4" and 8"
with some position limit switches. We only require the open and close position and nothing in between. These are manual valves and they do not require an accuator. There is a screw shaft that extends out of the handle when the valve is open and retracts when the valve is closed. Typically, I've seen these with a plexiglass cover to indicate position. In our case these covers are broken and no longer used. We are considering making some new covers with proximity switches installed to indicate position. It seems like there has got to be some off-the-shelf solution but the manufactures tell us to buy an accuator. Anyone have a solution?
Thanks in advance.
I was
Thanks in advance.
I was
