Gradstructengineer
Hi all,
I have to design the walls of a valve pit to restrain thrust from the pipes going in, could you please advise me on how to calculate the thrust force from a pipe that's passing through the valve pit walls (with puddle flanges), no bends or change in size of the pipe as it is passing through. In the middle of the valve pit, there is a tee junction, for this tee junction where can I provide the thrust block, do I need to provide one? Is the thrust force from the tee junction going to be equally divided to the two side walls?
thanks in advance
thanks in advance
