Remember that an O-ring failure at low temperature caused the Challenger shuttle explosion in 1986. Elastomer applications such as valve packing selection are more complex than most people recognize. One material may be suitable for a rotary valve and not for a sliding stem valve. Many grades of Viton exist. Few (if any) are compatible with amines. Few of the Teflon products are suitable for valve packing much above 400 degree F but may still be well suited for a seal component. Some materials absorb CO2 and decompress explosively when depressured. Some materials may work well in certain shapes and not other shapes. Some applications may require products with thermosetting properties instead of elastomers. Sometimes ceramics or glass may be best although not likely for valve packing. Some seal materials hold up to rough surfaces – most don’t.
Define the needs such as selecting an elastomer for the packing or seal to maximize the equipment reliability and minimize the risk of failure within a reasonable price. Don’t always select Kalrez. Some products are best used where nothing else works.
In addition to the base elastomer material there are different curing systems, additives, fillers, uniformity specifications, densities, hardness, etc. Checkout ASTM publications for product specifications, etc.
Search the manufacturers’ web sites such as DuPont Dow Elastomers, Green-Tweed, for technical product downloads for chemical compatibility and other properties. Obtain data on Nitrile (HSN/HNBR), Ryton, PEEK, Aflas, Perfluorocarbons (Kalrez/Chemraz),
Search the web for technical advisories regarding seal failures.
As mentioned, good charts are available on the web from sites such as Air Products, Flow Serve, … Publish your report here and I will download it.
