I have problem with a valve. I have service that outlet pressure should be -14.7 psig.Inlet pressure is 84.8 and pressure drop is 99.49 and line size is 0.75" and i can changed it to 1". media is nitrogen ( gas). Flow rate is 25 lb/h.
I run the sizing program. The program result say me the MACH # is 1 and sonic diameter 6.114 and also software say me you should chose larger line size but i can not.
please advised me what shall i do for this application?
