Valve Gear Box
marah
AE
I am working in an oil field company , have different valve size and rating , I need to order Gear Box for I have experienced alot that Gear Box get damage .
How can I specify and order different Gear Box to keep them stand by ?
Need an advise.
regards
Normally the valve manufacturer must make the interface from the gear box to the valve. Therefore I suggest you start your search with the valve manufacturer.
Clif6361
There are many manufacturers spacialize on actuation of all types of valves, who can fulfill your needs. ( BRAY, AUMA, ROTORK etc.).I'm sure that you find something for you there. Take attention to flange connection between valve and gear box, the nominal torque of the gear box and the necessary torque for actuating the valve.
By the way - I'm a valve designer
