Stanweld/Carburize;
As always, your points are well taken, especially the validation approach that BVMan performed in comparison to the requirements in A-703. Going back to A-352, there is a statement under heat treatment indicating that.. "liquid quenching of the ferritic grades is normally required to meet the mechanical property requirements of heavier sections (of which I would consider the flange) and will greatly enhance the low temperature properties of the thinner sections". In addition, A-352 provides two options for heat treatment of the castings - normalize and temper OR liquid-quenched and tempered condition. The valve size or class was not mentioned in the original post, so it could be that the flange thickness would prohibit formation of a fine grained, tempered microstructure with the normalized and tempered condition.
Despite the technique performed by BVMan, the concern that I have is the much lower than anticipated Charpy impact values even at -20 deg C (which in my opinion should have at least met the minimum Charpy impact requirement in Table 1 of 16J at -46 deg C). If the in-situ Charpy impact test values would have at least met 16J at -20 deg C, I would agree that with the thicker portion of the casting (the flange), you will have variability in Charpy impact test values. However, the range of 7 to 10J at -20 deg C is still too low for LCC cast material. To me, this raises a big red flag to investigate further. Perhaps the casting heat treatment should have been specified as liquid-quenched and tempered?
