Vacuum System Pressure Drop Calculations
hondashadow1100vt
I need to size some lines for a vacuum system for a critical service. The pressure range is from 0 to 24 inches of Mercury vacuum (in Hg V). I have looked through a number of different resources to identify the right equations to use for pressure drop in vacuum lines and performed some calculations using different methods. I am finding a lot of seemingly conflicting information that produces differing results. I am wondering what the industry best practice is for calculating pressure losses in a vacuum system. Ideally I am looking for a referral to a handbook, paper, etc. that prescribes how to do it.
I will be very grateful for any insight/feedback that can be offered in this regard.
Thank you!
An excellent starting point is Bernoulli's book "Mechanica" later put in algebraic form in 1759 by Leonhard Euler
hondashadow1100vt,
I was able to find a book called "Handbook of Vacuum Science and Technology" on google that appears to be quite decent in describing vacuum systems. I recommend you to take a look on it.
But please bear in mind that if this is truly a critical service, you should seek the guidance of a more experienced engineer on this subject.
Have you checked Ludwig? Pressure drop in vacuum system, unlike pressurised flow, more relates to the time duration in which you need to get to a final pressure from initial pressure. You can use any low pressure gas equations.
