magnograil
New member
I am building a programmable ignition but so far have not been able to find what the range of retard and vacuum are typical. My Alfa V6 manual gives 250 mbar = 0 deg and 380 mbar = 10 deg which does not make sense (250 mbar = 3.626 psi, 380 mbar = 5.511 psi). Intake vacuum ranges from around 14 psi at idle, closed throttle, to 2-3 psi at high RPM, full throttle.
The circuit will measure the manifold vacuum with a pressure trandsucer. Once the unloaded vacuum curve is known, the difference between the calculated and measured vacuum can be used to add in a retard value to the RPM advance curve.
I intend to use this on various vehicles so general information would be appreciated.
Thanks.
Thanks.
