TheRubberbandMan
Hello all, I was hoping you could help settle some confusion I have about vacuums.
Suppose I have a perfect piston. It is sealed on one end and exposed to atmosphere on the other. The inside of the piston is a perfect vacuum. For simplicity's sake we'll assume the piston's face has an area of 1 square inch. The seal is perfect, the vacuum is absolute, and the piston is made of an indestructible and rigid material. Now we hang a weight, P, on the piston in an attempt to pull it apart. Below is a crude MS paint drawing I made to illustrate:
So here is my question: If P is equal to 14.7 lbs (enough to counteract the atmospheric pressure), does the piston slide all the way out? Does it stabilize and then require more weight to pull further? Why?
My thought process here is this: Because the pressure differential cant actually change due to the vacuum being already at absolute zero, the weight would simply counteract the force and slide out with a constant velocity. My colleague believes that pulling this piston apart would get more and more difficult the further you pull it. Who's right?
