Vacuum OR hydrotest of RC pipes-Stormwater
Good_Guy
28
DN1200 RC storm water pipe lines test
Pipe test procedure will be modified to suit the design pressure of 60KPA which is less then the design test pressure, 90Kpa, of the RC pipes
Which is preferable?
and
how to decide if vacuum test or hydrotest?
Thanks to all
Dear Good_Guy,
Are you following AWWA?
Anyway, these are normally hydro-tested at the required test pressure. Then the weld joints are internally lined and finally there is a golden joint.
Regards.
DHURJATI SEN
Kolkata, India
