Vacuum Lifts 1
tegefe
Industrial
I am interested in purchasing a vacuum lift with a jib for under $10k. It will need to lift steel sheets weighing approximately 100 lbs and it will need to have the ability to rotate on all axis. Is this a possibility or do I need to fork over more?
Tegefe,
We currently have a vacuum lift on a jib crane. I'm not too sure what the max load is for this unit. But I don't think it'll rotate in all axises. The one we have costs $7500 so it might go up a bit more for the movement you may want. But I really couldn't say how much. Hope this gives you some idea.
JeffdlS
