Sorry for the "noob-ness" of my first post. Hopefully I've put it in the right forum.
I am trying to design a vacuum chamber window with a working range as low as 10^-7 Torr. The size and form of the window are dictated by the existing chamber and the blank aluminum panel that the window will replace. The window is for normal observation and doesn't require specific optical properties other than visible light transmission.
Originally I wanted to use a cast acrylic but I'm concerned with outgassing. The advantage of acrylic is the ability to make it 477x777mm at a relatively low cost.
Fused-Silica Quartz seems better suited for VH/UHV but is seems much more expensive per unit of viewing area.
The task will get axed if it is prohibitively expensive or minimally functional. Is there an option that I have overlooked?
Thanks,
Rick
Thanks,
Rick
