J
Johannes Teubner
Guest
I have been thrown into the wonderful world of Catia V5R16 and have some beginners questions apparently not covered by the tutorials freely available. Online help is not installed.
First off, I just need Catia to do some simple constructions for feeding into CFDesign. That tool constrains the workflow somewhat, e.g., I'm restricted to just one body per part. In addition, I have to use a german version, so please consider that I might using a wrong term here and there.
The situation: My scene will consist on a few dozent parts. While I know all coordinates for my sketches, I find it a waste of time to enter them and would like to use snapping features if available. What I found out is that apparently snapping is restricted to objects in the same sketch. So, up to now, I have to draw objects in a sketch that contains reference points, cut them out afterwards and clip them into a new sktech associated with a new part.
Is there a better way? Is it possible to snap to corners from objects defined in a different sketch?
Thank you very much.
