V5 specification tree - How to print it? 1
griffith
Aerospace
GB
I'm sure that there must be an easy answer to this, but how do I print the specification tree. I can not find any way to do it
Try clicking on the tree or the axis system in the lower right corner of your monitor. This should allow you to zoom the tree in and out. Right click and then click on "print whole" to print the tree.
forfun
Hello there.
You can also try to save the Assembly as an .txt file.
This will give you the tree structure with expanded nodes.
-Bjod
Another option would be download a program called snag it from the internet it is free to download and grabs the whole window.
use "PRINT SCREEN" button.
Open a paint and hold "CTRL" and "V" to paste.
then save in BMP or JPG format.
johnny
Hi there
I found in Dassault documentation a script which allows you to write the name of selected products in a text file .
' COPYRIGHT DASSAULT SYSTEMES 2001
Option Explicit
' Purpose : Write the name of selected products in a text file.
' Assumptions : A CATProduct document should be active.
' Author :
' Languages : VBScript
' Locales : English
' CATIA Level : V5R7SP3
' Purpose: Build the complete name of a product.
' Inputs : ioProduct Product the product
' Outputs: osName String the complete name
Sub BuildName ( ByRef ioProduct, ByRef osName )
osName = ioProduct.Name
Dim oRoot As Product
Set oRoot = CATIA.ActiveDocument.Product
Dim oCurrent As Product
Set oCurrent = ioProduct
While (oCurrent.Name <> oRoot.Name)
Set oCurrent = oCurrent.Parent.Parent
osName = oCurrent.Name+"\"+osName
Wend
End Sub
' Purpose: Main.
Sub CATMain()
' Initialize
Dim sTitle As String
sTitle = "Write name of selected products"
Dim sExtension As String
sExtension = "txt"
' Create the file environment
Dim oFso As FileSystem
Set oFso = CATIA.FileSystem
Dim oFile As File
Dim oTextStream As CATIATextStream
' Open the output file
Dim iReturnCode As Integer
iReturnCode = vbRetry
While (iReturnCode = vbRetry)
' Retrieve the path from the user
Dim sFilePath As String
sFilePath = CATIA.FileSelectionBox(sTitle, sExtension,
CatFileSelectionModeSave)
If (sFilePath = "") Then
iReturnCode = vbCancel
Else
' Verify the existence of the output file
sFilePath = sFilePath+"."+sExtension
Dim iOverwrite As Boolean
iOverwrite = False
If (oFso.FileExists(sFilePath)) Then
' Ask user if output file exists
iReturnCode = Msgbox("The file "+sFilePath+" already exists
! Do you want to overwrite it ?", vbQuestion+vbAbortRetryIgnore, sTitle)
If (iReturnCode = vbAbort) Then
ElseIf (iReturnCode = vbIgnore) Then
iReturnCode = vbOK
iOverwrite = True
End If
else
iReturnCode = vbOK
End If
' Create the output file
If (iReturnCode = vbOK) Then
On Error Resume Next
Set oFile = oFso.CreateFile(sFilePath, iOverwrite)
If (Err.Number <> 0) Then
Err.Clear
iReturnCode = Msgbox("Cannot Create "+sFilePath+" !",
vbExclamation+vbRetryCancel, sTitle)
Else
Set oTextStream = oFile.OpenAsTextStream("ForWriting")
iReturnCode = Msgbox("Cannot open "+sFilePath+" as a
text file for writting !", vbExclamation+vbRetryCancel, sTitle)
End If
End If
On Error goto 0
End If
End If
Wend
' Write the name of selected products
Dim oSelection As Selection
Set oSelection = CATIA.ActiveDocument.Selection
' Retrieve the selected products
Dim oProduct As AnyObject
Dim sCompleteName As String
While (Err.Number = 0)
Set oProduct = oSelection.FindObject("CATIAProduct")
If (Err.Number = 0) Then
' Write the name
BuildName oProduct, sCompleteName
oTextStream.Write sCompleteName+vbCrLf
End If
Wend
On Error Goto 0
' Clean
Set oFile = Nothing
Set oFso = Nothing
' Report
Msgbox sTitle+" completed !"
End If
End Sub
Fernando
