V5 REL 12 SP5 DRAFTING PROBLEMS
oxford
Aerospace
I HAVE JUST LOADED SP5 & HAVE HAD PROBLEMS WITH ANGLE DIMS. SHOWING A '@' SYMBOL INSTEAD OF A DEGREE SYMBOL. THIS WAS ON A REVISION TO A DRAWING THAT I ORIGINALLY CREATED IN AN EARLIER RELEASE (NOT SURE WHICH). ALL NEW ANGLES I TRY TO ENTER HAVE THE SAME PROBLEM. ANYBODY EXPERIENCED THIS. ALSO THE QUALITY OF ISOMETRIC VIEWS IS POOR. WHEN CURVED SURFACES MEET FLAT SURFACES LINES ARE MISSING. THIS HAS BEEN A PROBLEM ON ALL V12 RELEASES. ANY HELP WOULD BE APPRECIATED.
Oxford - have you notified IBM or Dassault of these problems?
Have you also run a CATDUA on the part? You said it was created originally in an earlier release. This might solve some of your problems, if they persist, contact IBM and issue a PMR(bug) with them.
