V cut
  • Thread starter Thread starter especial
  • Start date Start date
E
especial
Guest
Hi
Need help! How can I put a V cut normal to edge all the way around? In Patter
Proe 2001
TIA
AS
Try using a sweep, using the edge of your part as the trajectory.
Thanks for your reply
See if this is a little better. Its a tab 3 side and a half round. I need v cuts on top, bottom and half round. I would like to patten the v cut. I would hate to make individual features or v protrusions. Iam guessing the sweep will not let me rotate section 90 degrees.
|vvvvv-----.
AS
|vvvvv-----.
AS
I do not know what does a geometry look like but try it this way:
1. sketch a curve
2. put a point on the curve (either by length ratio or actual length)
3. make an axis through point normal to surface you use for orientation of v cut
4. make a plane throughpoint normal to axis
5. make a plane that will be used for sketching (through axis, normal to plane from point 4 and paralel to what you feel is right.
6. make a sketch using plane 5. and 4; dimension to point and axis
7. make a cut
8. make a local group of geometry from pt. 2 through pt. 7
9. pattern the group using point parameter
This looks complex but in fact it is not. Have a good patterning.
|--V-V-V-V-----
Another solution:
1. Sketch a composite curve on top, botton, and half round edges
2. Put a point pnt1 on the curve (either by length ratio or actual length)
3. Make a dtm1 plane through point normal to datum curve(this will allow you to rotate around half round normal)
4. Make a dtm2 plane through point normal to dtm1
5. Sketch V cut. Use dtm2 for sketching dtm1 for orientation.
For ref use dtm1 and pnt1
6. Group all and pattern
AS
