Dear All ,
Due to the non availability of pressure reducing valves from 40 bar to 10 bar , I will install two valves in series the first 40-16 bar and the second 16-10 bar , Is there are any limits for the distance between both valves ?
The valves are of 2" size , to be connected to 2" steel line to take water from a 16" discharge line of booster pump that discharge water at 40 bar . the 2" steel water line is to feed the operation building at the booster station and other water hydrants
